I have seen this error discussed a couple times. But never any real solution. I am getting this error for one of my hosts listed in the Hosts Configuration:
Get value from agent failed: Cannot connect to [fmt01.mydomain.com:10050] [Interrupted system call]
It is a Windows 2003 host. I have many other Windows 2003 hosts working fine (same Windows 2003 CD used also). The connection seems fine as the zabbix_sender is working (I am getting Items from the sender). But anything polled from agentd is not showing.
On the zabbix server, a similar error is shown in the zabbix_server.log:
4701:20100120:093850 Item [fmt01.mydomain.com
roc.num[Apache.exe]] error: Get value from agent failed: Cannot connect to [fmt01.mydomain.com:10050] [Interrupted system call]
This is Zabbix 1.6.6 and Agent 1.6.6 also. So what can I do to debug more?
roc.num[Apache.exe]] error: Get value from agent failed: Cannot connect to [fmt01.mydomain.com:10050] [Interrupted system call]This is Zabbix 1.6.6 and Agent 1.6.6 also. So what can I do to debug more?
