Zabbix Agentd on AIX 5.3
  • ivrhall
    • Jan 2010
    • 13
    Which versions of zabbix_agentd work in AIX 5.3? I installed a fresh zabbix 1.8 server and had hoped to use 1.8 agents. However, I am encountering the same libiconv.a load failure others are reporting. I have not seen any patches, fixes, or workarounds for this. What is the most up-to-date version of complied AIX zabbix_agentd that will run under AIX 5.3.
  • ivrhall
    • Jan 2010
    • 13
    Anybody???
    Do I need to go back as far as 1.4.6? Anything in the 1.6.x series work on AIX 5.3?
    • tchjts1
      • May 2008
      • 1605
      You should not have any issues running Zabbix agent 1.8.1 on AIX 5.3 (With Zabbix server 1.8 or 1.8.1)
      I run it here and it works fine.
      Pre-compiled agents are available here: http://www.zabbix.com/download.php
      • ivrhall
        • Jan 2010
        • 13
        Success 1.8.1 on AIX 5.3
        Thank you. 1.8.1 seems to work fine.
