Problem setting up web monitoring
  • badener
    • Sep 2009
    • 42
    Hi folks,
    I upgraded to 1.8 recently and wanted to try out web monitoring.
    I've tried to follow the manual - setup Application, then go to Configuration - Web, choose hostgroup and host and click "create scenario".
    When I click "Select" for the application I get error "ERROR: No permissions !" although I work as admin. I did notice that the hostid gets lost.
    In the configuration of web monitoring URL looks like this
    "httpconf.php?sid=fb7a502c9afa6c50&hostid=10017&fo rm=Create+scenario"
    The popup URL looks like this
    "popup.php?dstfrm=form_scenario&dstfld1=applicatio n&srctbl=applications&srcfld1=name&only_hostid=0 "
    Anybody have a similiar problem before ?
    Besides the problem with web monitoring setup everything seems to be working ok.
  • jlorier
    • Jul 2009
    i have seen this kind of behaviour in Internet Explorer. In Chrome things are much better, you could try this also.
    Regards, Johan
    • badener
      • Sep 2009
      • 42
      no luck
      so far I've tried Internet Explorer, Firefox and Google Chrome - no luck
      I upgraded to 1.8.1 and migrated the database to utf-8 - no good
      I click on "Create Scenario" - in the Scenario box I click on "Select" beside the application box and I get a new window with message "Error : no permissions!" and the Url: http://my.zabbix.server/popup.php?ds...&only_hostid=0
      The only_hostid=0 disturbs me a bit, because I did select a host and it's id is 10017 - not 0
      anybody got any more ideas - where could I check for messages ?
      debug is enabled but when I look at that I see many sql commands but no errors
