how to reset the Admin password without gui access
  • mrmurdock
    • Aug 2009
    • 85
    The title says it all. Its zabbix 1.8. Thank you. I know it must be a database command, but, not familiar enough with mysql to do it.
  • nelsonab
    • Sep 2006
    • 1233
    In the user table set the password for the admin user to blank. Then you can log in without a password, however you will need/want to change it to something with a password quickly. :-D
    RHCE, author of zbxapi
    • mattlf
      • Feb 2010
      Hi
      Our sysadmin left and I have to get into zabbix and try to get access to the super user
      In the user table I set the password for the admin user to blank
      update users set passwd='' where name='Zabbix';
      mysql> select name, alias, passwd from users where name='Zabbix';
      | name | alias | passwd |
      | Zabbix | Admin | |
      I restarted zabbix : ./zabbix_agentd stop; ./zabbix_agentd start
      However, when trying to log in, I get
      ERROR: Login name or password is incorrect
      I would appreciate any help. Is there some logging I can turn on to see what is happening
      Thank you
      • mrmurdock
        • Aug 2009
        • 85
        Fortunately for me I was just at install so I dropped the database and re-created it from scratch.
        However, Mysqladmin makes sure the password is encrypted. I using RHEL5, with 5.0 of mysql.
        From the linux shell as the root user,
        mysqladmin -u <user> password '<new_password>'
        mysqladmin -u <user> -h <host> password '<new_password>'
        • mattlf
          • Feb 2010
          Thank you for your reply.
          But this would be for the mysql user
          I am actually trying to reset the zabbix admin/super user password
          And this does not work for me
          • mrmurdock
            • Aug 2009
            • 85
            Go to www.mysql.com and do a search for Mysql 5.0 Manual...
            thats about as much as I can do.
            • richlv
              • Oct 2005
              • 3112
              update zabbix.users set passwd=md5('mynewpassword') where alias='Admin';
              • mattlf
                • Feb 2010
                cool. it works. Thanks a lot
                I had to restart the web server as well
                • chocho63
                  • Jun 2005
                  • 53
                  Help password
                  I've just upgraded to 1.8.1 from 1.1.
                  Can't connect... This SQL statement works, but I still can't connect...
                  • aic
                    • Oct 2010
                    • 50
                    Hi All,
                    Please help I will need to do the same for Oracle environment....
                    Thanks!
                    • nelsonab
                      • Sep 2006
                      • 1233
                      aic, have you tried any of the above?
                      • walterheck
                        • Jul 2009
                        • 153
                        on a sidenote: shouldn't the password be salted in the database?
                        Free and Open Source Zabbix Templates Repository | Hosted Zabbix @ Tribily (http://tribily.com)
                        • aic
                          • Oct 2010
                          • 50
                          Hi nelsonab,
                          Actually, I didn't tried the options suggested above because I am using Oracle Database instead of MySQL.
                          I fixed this issue applying the default hash (password) for Admin user.
                          Anyway, thanks for your reply!
                          Have a good week.
                          • zhanghui8059
                            • May 2011
                            Originally posted by aic
                            Hi nelsonab,
                            Have a good week.
                            I use oracle database,and use update users set passwd=hash(password) where name='zabbix';
                            but oracle error is not hash,pls help,how are you doing?THKS!
                            • igalsc
                              • Jan 2021
                              • 20
                              #15
                              Thank you, this worked for me with Zabbix 5.2
