Zabbix front-end php starttls
  • alubel
    • Jan 2010
    • 13
    within include/classes/class.cldap.php I notice that there is a starttls option, what do we have to do to enable LDAP tls/ssl over port 389? I was hoping to avoid messing with /etc/openldap/ldap.conf and putting ssl certs on etc.
    I basically have a need to encrypt not only HTTP traffic but to encrypt our passwords that fly over the network to our Active Directory server.
    If this isn't the right direction to accomplish that, please let me know!
  • alubel
    • Jan 2010
    • 13
    Is there no way to get TLS over port 389?
    • tarufeti
      • Jul 2009
      I have the same problem. Can you implement the encrypted option?
      • BDiE8VNy
        • Apr 2010
        • 680
        Just set 'starttls' to 'true':
        [root@zabbix ~]# diff -C2 /var/www/html/zabbix/include/classes/class.cldap.php.orig /var/www/html/zabbix/include/classes/class.cldap.php
        *** /var/www/html/zabbix/include/classes/class.cldap.php.orig	Mon Feb 21 20:44:51 2011
        --- /var/www/html/zabbix/include/classes/class.cldap.php	Mon Feb 21 20:33:31 2011
        *** 48,52 ****
          				'version'=> 		3,
        ! 				'starttls'=>		null,
          				'deref'=>			null,
        --- 48,52 ----
          				'version'=> 		3,
        ! 				'starttls'=>		true,
          				'deref'=>			null,
        [root@zabbix ~]#
        Don't forget to disable the need of a valid server certificate in case you havn't installed/configured a proper CA certificate:
        --- SNIP /etc/openldap/ldap.conf ---
        TLS_REQCERT     allow
        --- END /etc/openldap/ldap.conf ---
        • StephenKing
          • Sep 2011
          • 19
          Is there no way to define this in a clean way through configuration?
          Steffen
          • zalex_ua
            • Oct 2009
            • 1286
            Who would like to create a feature request ?
            • StephenKing
              • Sep 2011
              • 19
              Done: https://support.zabbix.com/browse/ZBXNEXT-1596
              • MikeHurn
                • Jun 2020
                As an FYI - In Red Hat & CentOS 8.x SSL has been disabled!
                See https://access.redhat.com/documentat...uring-networks
                I don't have much hope in running ldaps BTW it failed when I tried to configure it!
