I have a problem when I create a new graph. I want to use the feature : "Y axis MAX value" which I put to "Item" :
Items value are :
And when I check the graph :
So, I don't understand why the Y axis MAX value is not at the good value, it's at the item value "Used disk space on c:" and not at "Total disk space on c:"
I already check on my items configuration.
I tried with changing the item, use the direct host item and not the template item :
Thanks.
Items value are :
Thanks.
