Trigger problem for log file monitoring
  • nicolas.rabine
    • Jan 2010
    I'm trying for the first time to monitor a log file with an item and a trigger.
    Here is the configuration I've done :
    - Item "Zabbix agent (active)" configuration :
    log["D:\linkbynet\scripts\Zabbix\fichier.txt","error", "UTF-8",100]
    - Trigger configuration :
    {Host_Nico:log["D:\linkbynet\scripts\Zabbix\fichier.txt","error", "UTF-8",100].str(error)}=1
    I want the trigger to send an alarm when the word "error" is found in the file "D:\linkbynet\scripts\Zabbix\fichier.txt" on the agent side, but the trigger is never sending alarms even though the file has the word "error".
    Could you please help about it?
    Thanks a lot in advance.
    Nicolas
