Hi all,
I'm experiencing the same problem described on this post
Master (node 1) with the "All" nodes option selected should display both node 1 and node 2 data, but it shows only itself.
I'm using MYSQL... not postgresql
Seems to me that nodes 1 and 2 are correctly communicating with each other:
@@@From node 1:
15190:20100211:114755.351 server #17 started [Node watcher. Node ID:1]
15176:20100211:120218.423 NODE 1: Received history from node 2 for node 2 datalen 762
15174:20100211:120218.440 NODE 1: Received history_uint from node 2 for node 2 datalen 584
@@@From node 2
31852:20100211:115427.240 server #17 started [Node watcher. Node ID:2]
31852:20100211:120248.537 NODE 2: Sending history_sync of node 2 to node 1 datalen 728
31852:20100211:120248.551 NODE 2: Sending history_uint_sync of node 2 to node 1 datalen 410
On both nodes:
zabbix 1.8.1
mysql Ver 14.12 Distrib 5.0.51a
Debian 5.0
Any tips?
Thanks a lot,
Alf
@@@From node 1:
@@@From node 2
On both nodes:
zabbix 1.8.1
Debian 5.0
Any tips?
Thanks a lot,
Alf
