Hi
I am trying to upgrade from 1.6.x to 1.8.1
When running the update scripts, it has been hanging for few hours now on the following
... converting table history
and show processlist; shows the following
| 215 | root | localhost | zabbix | Query | 9020 | copy to tmp table | ALTER TABLE history CONVERT TO CHARACTER SET utf8 COLLATE utf8_general_ci |
select count(*) history also hangs
I was wondering if i could safely interrupt the update script and eventually truncate the history table (I am willing to loose the history)
Did anybody run into this issue ?
Thank you
Thank you
