Lost "Graph" menu in "Configuration" after upgrade 1.6 -> 1.8.1
  • pbergdolt
    • May 2009
    • 10
    I summit to your skills my problem.
    After upgrading from 1.6 to 1.8.1 in don't have anymore the "Graph" menu in "Configration" when I'm connected as "admin".
    I still can view created graphs, but as I don't have access to graph configuration it is not possible to create new ones.
    Any comment, or advice is welcome.
    Thanks,
    Regards
  • alucard95
    • Sep 2008
    • 38
    Graph Menu
    Hello
    In version 1.8, graph menu (like items, triggers) are available in:
    Configuration -> hosts
    and then, you can click on graph for the hosts you want.
    An other way:
    In the hosts menu, you have a little box (on the top at right) where you can select graph instead of hosts.
    Hope this will help you.
    Jonathan
