Unauthorized request issue 1.8 & 1.8.1
  • maxlock
    • Mar 2005
    • 32
    [ Problems solved by upgrading firefox3.0 to firefox3.6 ]
    Hi Folks,
    I'm currently running 1.8.1 and getting problems when trying to add to my configuration. Adding triggers is flakey sometimes they work, most of the time I get an unauthorized request error. I also get a consistant unauthorized request error when trying to configure cells in a screen. I have my own account and the admin account setup as super-admins with permissions on everything. This installation has been running and upgraded since 1.6, skipping the 1.7 branch. I upgraded to 1.8.1 from 1.8 hoping these problems would be fixed.
    It's getting to the point where for me zabbix is getting un-usable. We've got quite a large installation, and I don't want to have to move away.
    I've looked at the debug output in the gui and it gives the following when adding a cell to a screen for example:
    ******************* Stats for script *************************
    Total time: 0.315346
    Memory limit : 256M
    Memory usage : 1024K - 8.75M
    Memory leak : 7.75M
    SQL selects count: 9
    SQL executes count: 5
    SQL requests count: 14
    Time:0.000162 SQL: SET NAMES utf8
    Time:0.000111 SQL: SET CHARACTER SET utf8
    Time:0.000223 SQL: SELECT * FROM nodes WHERE nodetype=1 ORDER BY nodeid
    Time:0.001008 SQL: SELECT u.*,s.* FROM sessions s,users u WHERE s.sessionid='3aa3d29cb464747b8fbdd04884eaeb6a' AND s.status=0 AND s.userid=u.userid AND ((s.lastaccess+u.autologout>1266488922) OR (u.autologout=0)) AND ((u.userid BETWEEN 000000000000000 AND 099999999999999))
    Time:0.000245 SQL: SELECT MAX(g.gui_access) as gui_access FROM usrgrp g, users_groups ug WHERE ug.userid=3 AND g.usrgrpid=ug.usrgrpid
    Time:0.00016 SQL: SELECT g.usrgrpid FROM usrgrp g, users_groups ug WHERE ug.userid = 3 AND g.usrgrpid = ug.usrgrpid AND g.users_status = 1 LIMIT 1 OFFSET 0
    Time:0.009951 SQL: UPDATE sessions SET lastaccess=1266488922 WHERE sessionid='3aa3d29cb464747b8fbdd04884eaeb6a'
    Time:0.000228 SQL: SELECT g.usrgrpid FROM usrgrp g, users_groups ug WHERE ug.userid = 3 AND g.usrgrpid = ug.usrgrpid AND g.debug_mode = 1 LIMIT 1 OFFSET 0
    Time:0.007858 SQL: SELECT * FROM profiles WHERE userid=3 AND ((profileid BETWEEN 000000000000000 AND 099999999999999)) ORDER BY userid ASC, profileid ASC
    Time:0.000759 SQL: UPDATE profiles SET value_id=0, value_int=0, value_str='screenconf.php', type=3, source='' WHERE userid=3 AND idx='web.menu.config.last' AND ((profileid BETWEEN 000000000000000 AND 099999999999999))
    Time:0.000298 SQL: SELECT * FROM config WHERE ((configid BETWEEN 000000000000000 AND 099999999999999))
    Time:0.000788 SQL: SELECT title1, url1, title2, url2, title3, url3, title4, url4, title5, url5 FROM user_history WHERE userid=3
    Time:0.000676 SQL: SELECT title5, url5 FROM user_history WHERE userid=3
    Time:0.001449 SQL: UPDATE user_history SET title1=title2, url1=url2, title2=title3, url2=url3, title3=title4, url3=url4, title4=title5, url4=url5, title5='S_CONFIGURATION_OF_SCREENS', url5='screenedit.php' WHERE userid=3
    Total time spent on SQL: 0.023916
    ******************** End of script ***************************
    What can I do?
    -Cheers Max
    Number of hosts 98
    Number of items 13292
    Number of triggers 5506
  • Icenode
    • Apr 2009
    • 27
    I'm seeing this as well. It seems flaky for items and triggers etc...
    In Firefox:
    I can reproduce the error 100% of the time though by trying to add an IT Service. I get the error when I try to add the time, I never make it past that to actually add the service.
    Seems to be working in IE 8. I tried deleting cookies from firefox but still get same behavior.
    • Icenode
      • Apr 2009
      • 27
      I still get this same behavior when performing certain tasks after upgrading Firefox to 3.6.3
      I have noticed that less tasks are affected now though. For instance I can add a new Item to be checked, and I can modify triggers. Neither of which I could do before. I still can't create triggers from scratch and I still have problems editing IT services.
