No able to install zabbix 1.8 in hp unix system getting
  • bbroko
    • Feb 2010
    Hi ,
    We are using HP-UX ia64 system
    we try to install zabbix 1.8.1 in our system using oracel as a backend
    we came to know zabbix using oracle OCI
    i downloaded the libraries from Oracle site and copied the libs to the $ORACLE_HOME/lib
    when i try to configure zabbix
    (i use ./configure --enable-server --with-oracle=$ORACLE_HOME )
    but i am getting error
    checking for Oracle OCI headers in /software/ora/app/product/10.2/db/rdbms/public... yes
    checking if Oracle OCI version is >= 10.0... yes
    checking for Oracle version >= 11.x to use -lnnz11 flag... no
    checking for Oracle version >= 10.x to use -lnnz10 flag... yes
    checking for Oracle OCI libraries in /software/ora/app/product/10.2/db/lib... not found
    checking if Oracle support is enabled... no
    configure: error: Oracle OCI library not found
    can you please help me how to install ZABBIX in our env
    thanks in advance
