not able to install zabbix 1.8 with oracle as backend
  • bbroko
    • Feb 2010
    we are using HP-UNX ai64 server
    we try to install ZABBIX 1.8.1 to monitor the process with oracel 10.2 as backend
    we came to know it is using oracle OCI lib to connect to oracle wchic is not mentioned ininstallation doc
    we downloaded the libs from oracle site and copied the libs to the $ORACLE_HOME/lib dir
    and when we try to configure the application
    we are getting an error like
    checking for Oracle OCI headers in /software/ora/app/product/10.2/db/rdbms/public... yes
    checking if Oracle OCI version is >= 10.0... yes
    checking for Oracle version >= 11.x to use -lnnz11 flag... no
    checking for Oracle version >= 10.x to use -lnnz10 flag... yes
    checking for Oracle OCI libraries in /software/ora/app/product/10.2/db/lib... not found
    checking if Oracle support is enabled... no
    configure: error: Oracle OCI library not found
    can you please tell me how can i sort out this problem and to install the application.
    thanks in advance
  • Firm
    • Dec 2009
    • 342
    Post config.log (as attach) please.
    • bbroko
      • Feb 2010
      Thanks for your reply
      please find the attachment of the config.log
      and please help us on installing the application
      • JRE
        • Feb 2010
        • 16
        Did you do the OUI install with the larger install option? There is an option that specifies it contains developer libraries. You need this.
