Percentage Free Space Not Working
  • Jbest
    • Jan 2009
    I'm trying to monitor the percentage free space on 2 servers that have ~20TB of space. For some reason it's not working. Where is this value pulled from? Perfmon shows the right value. The agent doens't seem to pull any data at all. Ideas?
    The zabbix server is 1.8 and the agent on the windows 2003R2 SP2 32bit running the 1.8 agent.
    Thanks.
  • svenw
    • May 2008
    • 26
    from the zabbix server try using zabbix_get to see what value the agent delivers for the key in question.
    • Jbest
      • Jan 2009
      zabbix_get
      Sven,
      the zabbix_get command returns a value. I went back and looked and the error showing up is:
      Type of received value [20.050284] is not suitable for value type [Numeric (integer 64bit)]
      Any ideas? I verified that the 32bit agent is installed since it's a 32 bit server.
      Thanks,
      Jeremiah
      • svenw
        • May 2008
        • 26
        well, is the value correct, is there ~20% free?
        if so, then the bugwould be an inconsistency of item definition (integer) and agent return value (float). in this case i'd file a bug report and meanwhile just change the item type to float...
        • tchjts1
          • May 2008
          • 1605
          Previously discussed here:
