How to set host groups shown in "hosts status" and "system status"?
  • bigmac
    • Nov 2009
    • 21
    I was unable to find, WHICH hostgroups are shown in host/system status dashboards, and HOW to change them.
    Any ideas?
  • richlv
    • Oct 2005
    • 3112
    you can't customise that currently. it depends on data receiving and triggers, depending on where you are looking at
    • bigmac
      • Nov 2009
      • 21
      depending on where you are looking at[/QUOTE]
      If I understand you, just adding some trigger and/or data polling (item) to one or all host group members would propagate it to the "hots status". Am I right?
      How does it depend? What are the options? Need to show some hostgroups in host status widget.
      tia, Paul
      • richlv
        • Oct 2005
        • 3112
        in general, yes - having working items and at least one trigger should ensure that host/group appears everywhere in the monitoring section
        • bigmac
          • Nov 2009
          • 21
          Thanks! Why not add the info to the documentation? There are lot of data in the forums, but it is very hard to obtain, and search still does not work (captcha bug).
          • richlv
            • Oct 2005
            • 3112
            which section would you expect to see this information in ?
            • bigmac
              • Nov 2009
              • 21
              Dashboard/Screen, however, mostly unexisted yet.
              • richlv
                • Oct 2005
                • 3112
                btw, what captcha bug are you referring to ? search works perfectly fine for me when i'm not logged in, captcha works and everything
