SSH check error: Cannot connect to [127.0.0.1:22]
  • uraniumscrap
    • Mar 2010
    I have Zabbix server at host A and Zabbix agent at host B. Zabbix checks sshd at host B:
     18821:20100302:123138.143 Processing request.
     18821:20100302:123138.143 Requested [net.tcp.service[ssh]]
     18821:20100302:123138.144 SSH check error: Cannot connect to [127.0.0.1:22] [Connection refused]
     18821:20100302:123138.144 Sending back [0]
    But sshd at host B listens external IP.
    In configuration (server, agent) - external IP.
    Please, help me.
  • alixen
    • Apr 2006
    • 474
    Please, help me.
    You are obviously checking SSH with:
    that uses 127.0.0.1 by default.
    You can replace it with:
    net.tcp.service[ssh,<extenal_IP>]
    You can check documentation for more details : http://www.zabbix.com/documentation/...l/config/items
    Hope this helps
    Alixen
    http://www.alixen.fr/zabbix.html
    • bashman
      • Dec 2009
      • 432
      I get this error with ssh checks:
      Item [<hostname>:ssh.run[test,<hostname>]] error: Cannot connect to SSH server: gethost() failed for address '<hostname>' [Success]
      I don't know if I'm doing it well, I don't want to use the Password so I use Public key Authentication method.
      I have in 'Public key file' field:
      /home/zabbix/.ssh/id_rsa.pub
      and in the 'Public key file' field:
      Is this correct?
      978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
      • bashman
        • Dec 2009
        • 432
        I only got it to work when I used password.
        • bashman
          • Dec 2009
          • 432
          I got it to work with public key:
          Public key file: "id_rsa.pub" instead of the full path.
          Private key file: "id_rsa" instead of the full path.
