Zabbix 1.8.1 'Errors on page'
  • myccal
    • Oct 2009
    Just installed zabbix 1.8.1 on fedora. the server is running and the frontend appears to be ok at first glance. However, in the bottom left of IE there is a note that there are Errors on the page, and the pages don't change when selecting a new section in the dropdown menus. For example, if I go to the configuration>host page then change the dropdown to triggers, nothing happens. Has anyone seen this behavior before? Any ideas on how to fix it? Thanks.
  • arli
    • Jan 2008
    • 71
    Maybe you can click on the icon by the "errors on the page" message, to see what this error is about.
    Or turn on script debugging and see the same thing then:
    Tools > Internet Options > Advanced > Browsing > Disable script debugging - uncheck checkbox
    Another good idea would be to check your apache error log.
