Monitoring disk usage in % and triggering it
  • ShivaS
    • Oct 2005
    • 51
    Hi, I am trying to trigger disk usage so it won't exceed 85% and nothing happens. (i made a test and made it >1 )
    How should i work in the case where percentage is used?
    {myserver.vfs.fs.pused[/].last(0)}>85 ?
    thanks
  • ShivaS
    • Oct 2005
    • 51
    ok found out that the it works after some remove/submit of trigger
    trigger shows up but no e-mail been sent when i am getting e-mails about anything else that is monitored on all the servers
    any ideas why mail not been sent in this case?
    i double checked all the actions and medias and so on...
    • ShivaS
      • Oct 2005
      • 51
      ok here found the problem or better say resolution
      created new user and not it works
      for some reason it didn't work well with admin user
      you may close this case;-)
      • Nate Bell
        • Feb 2005
        • 141
        I'm not sure if this was just a mistake made while copying your settings into your post, but the proper format for a trigger is
        {myserver[B]:[/B]vfs.fs.pused[/].last(0)}>85
        Nate
