icmppingsec[targetIP]
  • simonc
    • Jul 2009
    • 73
    Hi all,
    I'm trying to use this simple check to graph the response time between two server but it doesn't work... i get always 0.000 values
    I monitor two servers : A & B, and i would like to graph the response time between A and B, do you think it is possible with a zabbix check ?
    Simon
  • richlv
    • Oct 2005
    • 3112
    ping probably fails. does simple icmpping work ? have you configured fping correctly ?
    • simonc
      • Jul 2009
      • 73
      Yes, simple icmpping works. I installed fping package, what do you mean by configured correctly ? Is there a special configuration for zabbix ?
      My simple check is "icmping[IP_servB]"
      • richlv
        • Oct 2005
        • 3112
        re-reading your question, it looks like you are trying to ping one monitored host from another - but simple checks are always executed from the zabbix server.
        if you want to ping, you might have to use a userparameter - alternatively, one of the tcp checks might work
        • simonc
          • Jul 2009
          • 73
          Ok, i was thinking that target IP could be another server... but it's not.
          I resolv my problem with that :
          UserParameter=ping.bla,ping -c3 -t1 xx.xx.xx.xx | grep rtt | cut -d"/" -f5
          Thanks Richlv
          • benito103e
            • Jun 2010
            • 24
            Mistake ! sorry
