Import/Export on 1.8.1
  • jamesl73
    • Mar 2010
    I'm attempting to import a template from my 1.6.5 install to a fresh 1.8.1 and it fails with no error. I then just tried to export a default template from 1.8.1 and it exports a 0 byte file.
    Is Import/Export broken on 1.8.1?
  • tchjts1
    • May 2008
    • 1605
    Correct. Import/Export has issues in 1.8.1 You could try the latest nightly build... or just wait for 1.8.2 to be released. Maybe this week is what I last heard for the release.
    Nightly build is here: http://www.zabbix.com/developers.php
    • Peteris
      • Feb 2010
      • 89
      Have you got php-xml installed ?
