Zabbix server 1.8.1 dies when host trapper is enabled!
  • HEMA1
    • Jun 2008
    • 33
    We are trying to run zabbix 1.8.1, with a Dbdump from zabbix 1.4.6 (host/item/trigger). Zabbix 1.8.1
    runs smoothly when trapper is disabled. Problem is: When trapper is enabled zabbix server dies (stops).
    Sum up:
    Zabbix sever runs on: CentOS release 5.4
    DB (separate box) runs on PostgreSQL, Server version: 80309
    Last 22 lines from zabbix_server log
    8387:20100318:175453.294 Query [txnlev:0] [select min(clock) from trends_uint where itemid=17199]
    8376:20100318:175453.299 Trapper got [XXXX:State:1] len 13
    8376:20100318:175453.299 In process_mass_data()
    8376:20100318:175453.299 In DCinit_nextchecks()
    8360:20100318:175453.299 One child process died (PID:8376). Exiting ...
    8360:20100318:175455.305 Connect to the database
    8360:20100318:175455.345 Query [txnlev:0] [select oid from pg_type where typname = 'bytea']
    8360:20100318:175455.358 PostgreSQL Server version: 80309
    8360:20100318:175455.358 Query [txnlev:0] [set escape_string_warning to off]
    8360:20100318:175455.371 In free_database_cache()
    8360:20100318:175455.371 In DCsync_all()
    8360:20100318:175455.371 In DCsync_history(history_first:0 history_num:0)
    8360:20100318:175455.371 Syncing history data...
    8360:20100318:175455.371 In DCsync_trends() trends_num:0
    8360:20100318:175455.371 Syncing trends data...
    8360:20100318:175455.371 Syncing trends data...done.
    8360:20100318:175455.371 End of DCsync_trends()
    8360:20100318:175455.371 End of DCsync_all()
    8360:20100318:175455.371 End of free_database_cache()
    8360:20100318:175455.371 In free_configuration_cache()
    8360:20100318:175455.371 End of free_configuration_cache()
    8360:20100318:175455.371 Zabbix Server stopped. Zabbix 1.8.1 (revision 9702).
    TNX
