Upgrading 1.8 to 1.8.1
  • troloff
    • Mar 2010
    Maybe, the manual should contain some more information about upgrading from 1.8 to 1.8.1
    For me, it was not clear whether to run the dbpatches or not. At a first glance, I thought that the 1.8.1 patch was the same like the one for 1.8. But there are some differences (table node_checksum and some help messages).
    Since the 1.8.1 dbpatch fails
    ERROR 1061 (42000) at line 1: Duplicate key name 'actions_1'
    if you did an upgrade from 1.6 to 1.8 before, it may be necessary to "extract" the differences between 1.8 dbpatch and 1.8.1 dbpatch and apply them manually.
