Frontend errors with pre-1.8.2.x rev. 10923
  • simix
    • Jul 2006
    • 53
    I have two errors in the web frontend which are not present in 1.8.1.
    Note: Both errors show up only when logged in as Admin, but not as other user or guest.
    In the dashboard below "Last 20 issues" I see those errors:
    * Invalid argument supplied for foreach()[/usr/share/zabbix/frontend-php/include/blocks.inc.php:719]
    * Undefined index: [/usr/share/zabbix/frontend-php/include/blocks.inc.php:742]
    I ws unable to figure out why it fails because it shows the last 20 issues fine.
    The second problem is in when I show the triggers for group all / host all. I get the correct list of triggers but on the first line I can see a trigger which doesn't exist:
    Average PROBLEM Never 40y 2m 3w Acknowledged *ERROR* Show
    It seems that it tries to show a trigger which does not exist.
    Both errors don't show up with 1.8.1 so it must have happened in the pre-1.8.2 series.
    Regards,
    Simon
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    For some unknown reason, this trigger is left out without an item (thats impossible situation in normal processing). The simplest way is just remove it manually from DB by triggerid.
    Zabbix | ex GUI developer
    • simix
      • Jul 2006
      • 53
      Sorry but I don't know how to delete the trigger in the DB.
      I can see the triggerid in the link like this:
      /zabbix/events.php?triggerid=12201&nav_time=0&sid=2427e2fd cb8f1aa5
      So I expected we are talking about the triggers table where triggerid=12201
      Unfortunately that seems to be wrong.
      Where exactly is the bad trigger?
      Thanks,
      Simon
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        Yep we are talking about table triggers:
        SELECT * FROM triggers WHERE triggerid=12201;
        It should be there. Make shore that this is the trigger with wrong expression and then type:
        DELETE FROM triggers WHERE triggerid=12201;
        • simix
          • Jul 2006
          • 53
          I have checked this before but I don't see anything wrong with 12201:
          12198,{11198}>1000,icmpOutTimeExcds on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          12199,{11199}>0,icmpOutParmProbs on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          12200,{11200}>0,icmpOutSrcQuenchs on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          12201,{11201}>150000,icmpOutRedirects on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          12202,{11202}>100,icmpOutEchos on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          12203,{11203}>100,icmpOutEchoReps on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          12204,{11204}>100,icmpOutTimestamps on {HOSTNAME} is too High,,0,1,3,0,0,20,,0,0
          If something is wrong with 12201 why not with the others?
          • simix
            • Jul 2006
            • 53
            OK, I have just deleted the row and now it seems to work.
            Thanks,
            Simon
            • simix
              • Jul 2006
              • 53
              I have just checked data.sql and it looke like the trigger mentioned has been added by the initial database creation process:
              INSERT INTO triggers VALUES (12201,'{11201}>150000','icmpOutRedirects on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12202,'{11202}>100','icmpOutEchos on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12203,'{11203}>100','icmpOutEchoReps on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12204,'{11204}>100','icmpOutTimestamps on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12205,'{11205}>100','icmpOutTimestampReps on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12206,'{11206}>100','icmpOutAddrMasks on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12207,'{11207}>100','icmpOutAddrMaskReps on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              INSERT INTO triggers VALUES (12208,'{11208}>1000','icmpOutRedirects on {HOSTNAME} is too High','',0,1,3,0,0,' ','',0,0);
              triggerid 12201 and 12208 look very similar. Is there an error in data.sql which should also be fixed when 1.8.2 gets released?
              • dotelpenguin
                • Feb 2009
                • 14
                ..adding this because it also solved my problem.
                I had this same problem, tho I never noticed the weird trigger in the "recent triggers" (however it was there when I restored the db and tested).
                I had the problem with viewing all triggers in the configuration screen. It would crash the front end with
                Unsupported operand type in ...../include/triggers.inc.php on line 1537
                Deleting the trigger from the database was also the solution.
