Cannot compile Zabbix 1.8.1 :
./configure --enable-server --enable-agent --with-mysql=/zabbix/mysql --with-net-snmp --with-jabber --with-libcurl -enable-static
checking for putenv... yes
checking if Oracle support is enabled... no
checking for mysql_config... /zabbix/mysql/lib/mysql
configure: error: MySQL library not found
My LD_LIBRARY_PATH is set to : LD_LIBRARY_PATH=/usr/local/lib:/zabbix/mysql/lib/mysql
$ ls /zabbix/mysql/lib/mysql
libdbug.a libmyisam.a libmysqlclient.la libmysqlclient.so.14.0.0 libmystrings.a libvio.a libz.so
libheap.a libmyisammrg.a libmysqlclient.so libmysqlclient.so.15 libmysys.a libz.a libz.so.0
libmerge.a libmysqlclient.a libmysqlclient.so.14 libmysqlclient.so.15.0.0 libnisam.a libz.la libz.so.0.0.0
Does anyone have a suggestion ?
