Zabbix proxy fails with a query.
  • Pierreb
    • Nov 2009
    • 9
    I had a proxy 1.6 running before and upgraded it to 1.8.
    After that i have this spammed in the zabbix_proxy.log
    2525:20100401:114426.094 [Z3005] Query failed: [1054] Unknown column 'unique_dcheckid' in 'field list' [select druleid,iprange,name,unique_dcheckid from drules where proxy_hostid=0 and status=0 and (nextcheck<=1270115066 or nextcheck>1270115066+delay) and mod(druleid,1)=0]
    Anyone know what this means or how to correct it?
    Not sure if its related to a other problem i have that is the agent.ping is not working anymore from the proxy.
    Its showing 15 hosts as unreachable even tho its possible to do normal pings and i can login to the machines.
    The servers are all windows servers running version 1.6.6 of the agent.
  • richlv
    • Oct 2005
    • 3112
    database is not compatible between 1.6 and 1.8. as it's just proxy, remove its db aand re-create it (or just remove it and launch proxy again if using sqlite)
