I have two the same server (A and B)
Server (A) ipmi settings:
[code]
Server A:
ipmi ip - 192.168.200.10
ipmi port - 623
ipmi autentication algoritm: default
user:admin
password:admin
[code]
It's working
Server (B) ipmi settings
[code]
Server B:
ipmi ip - 192.168.200.11
ipmi port - 623
user:admin
password:admin
[code]
Not working I get some error:
Cannot connect to IPMI host []:0. ipmi_ip_setup_con() returned error 0x16
If I run manually ipmitool it's working and I get some values:
/usr/bin/ipmitool -I lanplus -H 192.100.200.11 -U admin -P admin sdr
Anotother different situation is, if I put ip ipmi from server B to settings server A is working.
Any ideas what could be wrong?
P.S
If I disable IPMI on host, the ipmi icon still is active and show me a error.
[code]
Server A:
ipmi port - 623
user:admin
password:admin
[code]
It's working
[code]
Server B:
ipmi port - 623
user:admin
password:admin
[code]
Ambient | 18.50 degrees C | ok Systemboard | 47 degrees C | ok CPU 1 | 30 degrees C | ok Main +12V | 12.44 Volts | ok Main +5V | 5.00 Volts | ok Stdby 5V | 4.96 Volts | ok Main 3.3V | 3.32 Volts | ok Battery +3V | 3.06 Volts | ok ICH 1.05V | 1.05 Volts | ok Stdby +3.3V | 3.35 Volts | ok Stdby LAN | 1.20 Volts | ok Stdby BMC | 1.20 Volts | ok MCH 1.25V | 1.22 Volts | ok MEM_VTT | 0.88 Volts | ok MEM 1.8V | 1.81 Volts | ok ICH 1.5V | 1.51 Volts | ok FAN1 SYS | 3720 RPM | ok
P.S
