Unable to get Information from Zabbix Agents
  • zabbixmvp
    • Nov 2005
    Hi All,
    Zabbix Server is Up and Running which shows zabbix_suckerd and zabbix_trapperd running.
    Zabbix Agent is Up and Running which shows zabbix_agentd is running.
    But when I look into the error log of zabbix_agentd which is /tmp/zabbix_agentd.log, I see the following error messages : -
    002279:20051104:205854 zabbix_agentd started
    002280:20051104:205854 zabbix_agentd 2280 started
    002281:20051104:205854 zabbix_agentd 2281 started
    002282:20051104:205854 zabbix_agentd 2282 started
    002283:20051104:205854 zabbix_agentd 2283 started
    002284:20051104:205854 zabbix_agentd 2284 started
    002280:20051104:221037 Error getpeername [Transport endpoint is not connected]
    002280:20051104:221037 Connection rejected
    I suspect that because of this, I am unable to get the information of the zabbix Agent on the server.
    Also, I have installed and started ZabbixW32.exe on a Windows Machine. But I couldn't get the information from that machine to the server.
    Any help would be useful.
    Thanks in Advance,
    Ch. Maruthi Vara Prasad.
  • elkor
    • Jul 2005
    • 299
    is the server's IP correctly configured in the agent's config file?
    remember to restart the agent if you modify the config
