Action not executed
  • mario.almeida
    • Nov 2008
    • 44
    Action not executed
    Hi All,
    I have installed zabbix 1.8.6. (still evaluating)
    My problem is the action part is not being called.
    The status of the trigger changes depending upon the conditions.
    And I have an action like Trigger = "web-00 on server web2 is down" which should send email.
    I did a tcpdump on the zabbix server to check if any connection to my SMTP server is created. But no connections to the SMTP server.
    So I assume that the action is not being called.
    If I change the user to Admin then the emails action part works.
    Can someone guide me to solve this problem.
  • mario.almeida
    • Nov 2008
    • 44
    Problem solved permissions issue
