Hello everyone,
I have a situation and I am wondering if this is normal.
I have a discovery setup to scan a subnet with both an icmp check and an snmp request. This part works perfectly. The scan is configured to every 4 hours.
I then have an action which checks if the received value is like Cisco and if the status is up and the uptime greater than 10 minutes. If all of these are true, the device is added to a group and then a template linked to it. This works fine to.
The problem is, in the template linked, there are two items, again an icmp ping check and an snmp request. The ping checks the responsiveness, then snmp request checks for a valid snmp configuration. Both items have triggers, and the SNMP trigger depends on the ping trigger. The ping trigger check that the last two pings were successful and the snmp trigger checks that a valid snmp response came through in the last 3 minutes. both items are set at 60 sec intervals.
The thing is, the SNMP trigger goes off when a device is discovered through this process...
Am I missing something in the process because I do not get why it goes off...
Any ideas?
Thanks!
Any ideas?
Thanks!
