Bug with graphs in 1.8.2
  • oneye
    • May 2008
    • 27
    Dear all,
    I'm experiencing a bug with graphs when I select pie or exploded type. When I select option "Legend" or "3D view" I can not save this options. I select them click save but when I open the graph I can see that the changes were never made.
    Thank you and best regards,
    oneye
  • richlv
    • Oct 2005
    • 3112
    yeah, i stumbled upon such a problem recently myself as well, but it seems to work ok in svn head. so you could try frontend from svn or the nightly build.
    • Jun.Liu
      • Apr 2007
      • 91
      I encountered same problem here.
      since I had made many modifications of frontend files by myself. I would like to know which files were updated for this bug? then I can pick it out and install to my installation.
