Unable to select configuration
  • Darwin
    • Apr 2010
    I seen some people solved this same issue by recreating the database and populating the data from scratch. but i did it like 10 times and cant figure why this is happening, here are the commands and the outputs on creating database
    i'm using postgres
    it shows some warnings but no errors, is this normal?
