i have about 300 hosts within my environment. Sometimes one of my co-works use the cdrom player. If he doesn't remove the cd, zabbix noticed this, and enables this item(example: drive E) The problem is that there is no free space on the cd, so i get a trigger.
Is there a workaround for this? It is to much work to disable the Trigger for drive E within each host, because i have a lot off hosts witch actually have a drive E
