icmppingsec and icmppingloss value =0
  • morhaven
    • Apr 2010
    • 22
    Hi I have setup two items in zabbix to get ping latency and pakcet loss.
    All I get is value returned 0.
    note ICPMping seems to work ok as I get value 1 or 0....
    what am I doing inccorect..
    zabbix 1.8
    Ubuntu 9.10
  • burtininkai
    • Sep 2009
    • 25
    Try to use the settings:
    For pingsec:
    For pingloss:
    Problem is in multiplier and Type of information. If You would carefuly search the forum You would find this
    MRK. Get Life, or Die Trying.
    • morhaven
      • Apr 2010
      • 22
      All works now.. needed to use float value..
