Item value usage in Trigger name.
  • burtininkai
    • Sep 2009
    • 25
    Just created few items to monitor NetAPP volume.
    1. To get Volume name: Key is aggvolnm.2
    2. To gaet Space usage: Key is aggvolpr.2
    Monitoring using SNMP all seems to be ok getting Values. Perfect.
    But also need to create Trigger which would send me an email, in which I would get information Volume name + space usage.
    Template name: UCB_NetApp
    In zabbix created trigger:
    Name: {{HOSTNAME}:aggvolnm.2} space usage > 90 %
    Expression: {UCB_NetApp:aggvolpr.2.min(#2)}>90 & UCB_NetApp:aggvolpr.2.min(#2)}<95
    Trigger fires up and email sending action:
    Default subject: {HOSTNAME}: {TRIGGER.NAME}: {STATUS}
    Default message: Hostname: {HOSTNAME}
    Problem: {TRIGGER.NAME}:
    Problem status: {STATUS}
    Severity: {TRIGGER.SEVERITY}
    Date and Time: {EVENT.DATE} - {EVENT.TIME}
    Last tested value: {{HOSTNAME}:{TRIGGER.KEY}.last(0)}
    But when getting email getting error:
    Server1: *UNKNOWN* space usage > 90 %
    In version 1.8 all was fine.
    What I've missed? Could You please show me the way? Thank You in advance.
  • MrKen
    • Oct 2008
    • 652
    Looks like that macro is not supported. Check the list of supported macros in the online documentation. http://www.zabbix.com/documentation/1.8/manual/config/macros
    Don't know why it worked in 1.8
    MrKen
    • burtininkai
      • Sep 2009
      • 25
      Seems like:
      {host:key.func(param)} should be working. in notifications not?
      • burtininkai
        • Sep 2009
        • 25
        All done.
        Trigger
        {{HOSTNAME}:aggvolnm.1.last(0)}
        Working perfectly for trigger name, but are vissible only for mail notifications. But still much better notification.
        Thank You for support. Thread can be closed.
