Map doen't show down hosts
  • patrick
    • Oct 2004
    • 57
    I'm using zabbix 1.1beta2. I've created a map with hosts I know some are up and other are down but they all are shown with the same Icon Off (Small one) and all are green "OK".
    Who can tell me what is wrong.
  • elkor
    • Jul 2005
    • 299
    A host with no items configured for it may display this behavior
    also: double check your map configuration. The way the existing UI operates, it's REALLY easy to add multiple hosts to your map with different names that are acutally triggering off the same host object.
    Basically, the map status reflects the active trigger status for any given host, so if you go to view:triggers and a host has items there then that status should be reflected on the map.
