Since version 1.8 of Zabbix, we've had problems linking templates to hosts. We thought it was fixed in 1.8.2 but it's still there. Basically, when you have a template that has a trigger that is dependant on another template, you cannot link it to a host. Example with two templates:
Template A (Server)
Trigger : Server is down
Dependency : Template B trigger Switch is down
Template B (Switch)
Trigger : Switch is down
If you try to add Template A to a host, you get an error. You have to manually remove the dependency on Template A, then re-add it afterwards. This is extremely time consuming. Is there any workaround?
Template A (Server)
Template B (Switch)
