Bug (1.8.2) : Deleting map with the API
  • sebastien
    • May 2010
    There is a bug when you try to delete a map with the API. Elements concerning this map are not deleted in the other maps.
    In the file class.cmap.php, line 677, I think you have to change :
    ' WHERE '.DBcondition('sysmapid',$sysmapids).
    by
    ' WHERE '.DBcondition('elementid',$sysmapids).
    Thank you for the API. With python, it's a real pleasure to interface our system with zabbix.
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Yes, you are right. It'll be fixed. Thank you. Registered as ZBX-2412
    Zabbix | ex GUI developer
    • sebastien
      • May 2010
      I don't know if this is the right place to post a new feature but I added the deleteElements function in the file class.cmap.php. Is it possible to add it in the next version ?
      PHP Code:
       * Delete Element from map
       * {@source}
       * @access public
       * @static
       * @since 1.8
       * @version 1
       * @param array $selements multidimensional array with selement objects
       * @param array $selements[0, ...]['selementid'] selementid to delete
      public static function deleteElements($selements){
      $selements = zbx_toArray($selements);
      $selementids = array();
              foreach(
      $selements as $num => $selement){
      $selementids[] = $selement['selementid'];
      self::BeginTransaction(__METHOD__);
      $result = delete_sysmaps_element($selementids);
      $result = self::EndTransaction($result, __METHOD__);
              if(
      $result)
                  return
      true;
              else{
      self::setError(__METHOD__);
                  return
      false;
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        1. You should post it at "Patches" thread.
        2. Such method will be added but in future, map elements manipulation will flow through Map::update method.
