spotty data in graphs
  • zac
    • Oct 2005
    • 16
    When I used v1.0 my graphs were great. Now after a new install of 1.1b2 my graphs are spotty for data. in some instances I see less then 10% of the data. where can I look to see what is wrong? The Zabbix_server log is filled with timeout errors, but I don't see any reference as to why the timeout occured (cleint or server connection)
    thanks for any pointers.
    -zac
  • bbrendon
    • Sep 2005
    • 873
    This has already been fixed in CVS. This was discussed and resolved in the forums awhile back. You can search for the fix if you want to patch 1.1beta2.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Nate Bell
      • Feb 2005
      • 141
      This is probably a partial solution to your problem. The timeout issues are another matter, and could also account for missing data in the graph. The linked fix should connect the bits of data you have, but will skip the data that's missing because of timeouts.
      Are you getting timeouts with only proc loads, or other items? How often are you monitoring these items? Is this happening for only one host, or several hosts?
      Nate
