Network data collection failed
  • thorko
    • May 2010
    I upgraded zabbix 1.6.6 to 1.8.2. Since then zabbix doesn't collect the traffic of the network interface anymore. In the zabbix server logs I get the following error message
    net.if.in[eth0,bytes]] error: Type of received value [7537381020711] is not suitable for value type [Numeric (float)]
    Whenever I change the item it is working for one time and the next time it fails again.
    I need to have a solution without loosing the historical data of this item.
    Any help would be appreciated.
    Cheers
    Thorsten
  • alixen
    • Apr 2006
    • 474
    It seems that it corresponds to this bug report https://support.zabbix.com/browse/ZBX-1126
    As it is marked as fixed in 1.8.3 which is not yet released, you may try latest nightly build.
    Regards,
    Alixen
    http://www.alixen.fr/zabbix.html
    • fratotec
      • May 2010
      • 12
      How to get nightly builds
      how do I get access or where do I find the nightly builds, to resolve the
      "not suitable for value type" problem
      thanks
      Franz
      • richlv
        • Oct 2005
        • 3112
        either checkout from svn, or download snapshots from http://www.zabbix.com/developers.php
