Memory leak in frontend ?
  • jarek
    • May 2005
    • 35
    Hello!
    I have heavy loaded zabbix server and every few days I need to restart apache, because it eats all memory.
    zabbix is running on actual debian stable with apache2.
    Did someone meet such problem ? I have few other zabbix installations working without any problem (but they are much smaller).
  • Tenzer
    • Nov 2007
    • 316
    Since the front-end only consists of PHP scripts, they can't really do much memory leaking, since the PHP process only runs as long as it takes to generate the page. Whenever a page has been served to a client, the PHP process will be gone and so is it's memory consumption.
    You should probably contact an Apache related forum instead, since it would be Apache which has memory leaks, if that is what you are experiencing. It could maybe also be some caching?
