Zabbix server behind nat
  • sslider999
    • May 2010
    I`m trying to monitor few servers on a different subnet, but the agent is not responding.
    Below is the firewall configuration:
    I`m a noob at iptables.
    #!/bin/bash
    ipt=`which iptables`
    # Filter Table
    # Clear any existing rules and setting default policy to DROP
        $ipt -F
        $ipt -X
        $ipt -P INPUT DROP
        $ipt -t nat -F
        $ipt -t nat -X
    # Reset all iptables counters
        $ipt -Z
    # CHAIN: SYN-Flood checking
        $ipt -N SYNFLOODCHECK
        $ipt -A SYNFLOODCHECK -p tcp --syn -m limit --limit 300/s -j RETURN
        $ipt -A SYNFLOODCHECK -p tcp --syn -j DROP
        $ipt -A SYNFLOODCHECK -j RETURN
    # Stop Syn-Flood
        $ipt -A INPUT -j SYNFLOODCHECK
    # lopback
        $ipt -A INPUT -i lo -j ACCEPT
    # SNAT & DNAT
        $ipt -t nat -A PREROUTING -d xx.xx.xx.28 -j DNAT --to-destination 192.168.1.185
        $ipt -t nat -A PREROUTING -d xx.xx.xx.27 -j DNAT --to-destination 192.168.2.203
        $ipt -t nat -A PREROUTING -d xx.xx.xx.26 -j DNAT --to-destination 192.168.2.4
        $ipt -t nat -A PREROUTING -d xx.xx.xx.25 -j DNAT --to-destination 192.168.2.21
        $ipt -t nat -A PREROUTING -d xx.xx.xx.31 -j DNAT --to-destination 192.168.2.7
        $ipt -t nat -A POSTROUTING -s 192.168.1.185 -j SNAT --to-source xx.xx.xx.28
        $ipt -t nat -A POSTROUTING -s 192.168.2.203 -j SNAT --to-source xx.xx.xx.27
        $ipt -t nat -A POSTROUTING -s 192.168.2.21 -j SNAT --to-source xx.xx.xx.25
        $ipt -t nat -A POSTROUTING -s 192.168.2.0/24 -d ! 10.0.0.0/8 -j MASQUERADE
        $ipt -t nat -A POSTROUTING -s 192.168.1.0/24 -j SNAT --to-source xx.xx.xx.192
        $ipt -t nat -A POSTROUTING -s 192.168.2.7 -j SNAT --to-source xx.xx.xx.31
    # VPN
        $ipt -A INPUT -s xx.xx.xx.83 		-j ACCEPT #
        $ipt -A INPUT -s xx.xx.xx.190		-j ACCEPT
        $ipt -A INPUT -s 10.0.0.0/12 		-j ACCEPT #
        $ipt -A INPUT -s 10.100.0.0/19		-j ACCEPT
    # Filter between local nets
        $ipt -A FORWARD -s 10.0.0.0/8 -d 0.0.0.0/0 -j ACCEPT
        $ipt -A FORWARD -s 0.0.0.0/0 -d  10.0.0.0/8 -j ACCEPT
        $ipt -A FORWARD -s 192.168.1.0/24 -d 192.168.2.22 -j ACCEPT
        $ipt -A FORWARD -s 192.168.2.22 -d 192.168.1.0/24 -j ACCEPT
        $ipt -A FORWARD -s 192.168.1.0/24 -d 192.168.2.25 -j ACCEPT
        $ipt -A FORWARD -s 192.168.2.25 -d 192.168.1.0/24 -j ACCEPT
        $ipt -A FORWARD -s 192.168.1.0/24 -d 192.168.2.35 -j ACCEPT
        $ipt -A FORWARD -s 192.168.2.35 -d 192.168.1.0/24 -j ACCEPT
    	# Zabbix server
        $ipt -A FORWARD -s 192.168.1.0/24 -d 192.168.2.2 -j ACCEPT
        $ipt -A FORWARD -s 192.168.2.2 -d 192.168.1.0/24 -j ACCEPT
    $ipt -A FORWARD -s 192.168.1.0/24 -d 192.168.2.0/24 -j DROP
    $ipt -A FORWARD -s 192.168.2.0/24 -d 192.168.1.0/24 -j DROP
    # Allow all FORWARD
        $ipt -A FORWARD -j ACCEPT
    # Allow INPUT established connections
        $ipt -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
    # ALLOW TOTAL ACCES FROM:
        $ipt -A INPUT -s xx.xx.xx.0/24     	-j ACCEPT #  Alc
        $ipt -A INPUT -s xx.xx.xx.122		-j ACCEPT #  Alc
        $ipt -A INPUT -s 192.168.1.0/24		-j ACCEPT # LAN Clients
        $ipt -A INPUT -s 192.168.2.0/24		-j ACCEPT # LAN Servers
        $ipt -A INPUT -s xx.xx.xx.35		-j ACCEPT # serv
        $ipt -A INPUT -s xx.xx.xx.130		-j ACCEPT #
        $ipt -A INPUT -s xx.xx.xx.131/32           -j ACCEPT
        $ipt -A INPUT -s 10.18.13.0/24              -j ACCEPT
    # Allow ports  ()
         $ipt -A INPUT -p tcp --dport 80	-d xx.xx.xx.29	-j ACCEPT
         $ipt -A INPUT -p tcp --dport 21	-d xx.xx.xx.29	-j ACCEPT
         $ipt -A INPUT -p tcp --dport 20	-d xx.xx.xx.29	-j ACCEPT
         $ipt -A INPUT -p tcp --dport 3389 		-j ACCEPT
         $ipt -A INPUT -p tcp --dport 5010		-j ACCEPT
    # Restrict SSH
    #    $ipt -A INPUT -s xx.xx.xx.248       -p tcp --dport 22 -j ACCEPT #
        $ipt -A INPUT -p tcp --dport 22 -j DROP # all rest
        $ipt -A INPUT -p tcp --dport 1433 -j DROP
    # Restrict ICMP
        $ipt -A INPUT -p icmp -s 192.168.1.0/24	-j ACCEPT # LAN Clients
        $ipt -A INPUT -p icmp -s 192.168.2.0/24	-j ACCEPT # LAN Servers
        $ipt -A INPUT -p icmp -s xx.xx.xx.0/24	-j ACCEPT
    #    $ipt -A INPUT -p icmp -j DROP # all rest
    # ALLOW ACCES FROM:
    The server is on 192.168.2.x network and has the following IP: 192.168.2.2
    I can monitor servers from 192.168.2.x network.
    On the 192.168.1.x network the agent dont respond on telnet.
    From zabbix server i can ping 192.168.1.x servers.
    The zabbix server has access to 192.168.1.x network:
    	# Zabbix server
    What rules i need to add in iptables that the agent can send data to zabbix server.
    Thanks for the support.
  • sslider999
    • May 2010
    Any suggestions?
    • karo2k9
      • Jan 2009
      • 27
      we set up a zabbix proxy in this case. Maybe this works for you as well
      Cheers
      Dominik
      • sslider999
        • May 2010
        Thanks for the info
        • bashman
          • Dec 2009
          • 432
          Did you add the nat ip in the Server parameter of your zabbix_agentd.conf files?
          978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
