Zabbix + apache
  • avrilspirit
    • May 2010
    Zabbix + apache
    I tried a script for apache and i have a small problem.
    When I try with an zabbix_get -s192.168.0.8 -kapache2.total_accesses
    script : here
    I received all the time this message :
    ZBX_NOTSUPPORTED
    My zabbix_agentd is well configured with ipserver 192.168.0.165
    and http://192.168.0.165/server-status works
    Can you help me ?
    I tried others script and always the same problem...
  • MrKen
    • Oct 2008
    • 652
    Try this:
    zabbix_get -s192.168.0.8 -k"apache2.total_accesses"
    HTH
    MrKen
    • avrilspirit
      • May 2010
      thanks for your response but no it's the same problem with " "
      • avrilspirit
        • May 2010
        I tried another thing with "user defined monitored parameters" to see if all predefined works or not.
        If i try the first : UserParameter=system.test,wholwc -1
        if i try with zabbix_get => it's works
        but why it's don't work with an external script ? the right of the file ?
