Not supported by ZABBIX agent
  • jplopez
    • Nov 2005
    I'm having a problem with Userparameter, the agent is returning Not supported by ZABBIX agent. I was reading back, and I made all the stuff I found in the forum.
    Userparameter=custom[cpu],/home/zabbix/cpu.php
    1. File permissions it's OK.
    2. the shell command didn“t return empty string or EOL only
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    Right off the bat, it looks like you might have a typo in your path for the UserParam command, you list it as /hom/zabbix Most systems, the home directory is /home/zabbix
    Unofficial Zabbix Developer
    • jplopez
      • Nov 2005
      Sorry, It was a mistake when I wrote the file path in the forum, the path is Ok,
      UserParameter=custom[cpu],/home/zabbix/test.php
