Scenery
I've zabbix 1.6.6 and zabbix 1.8.2 on both server I've defined triggers like this in order to launch a trigger when the router site is down
On the other hand I've defined the "IT Services" to obtain the site uptime LSA so the configuration is
ISSUE
"IT Service" work fine when only site trigger is launched, IT Service calculate well the LSA percent and Trigger alert send the mail as well.
But when the main site go down (in our case the core "H_Barbastro"), we are notified only about the core unavailability (no core and sub site unavailability), that is right, but no changes has been made over the "IT Services" Mequinenza LSA, so for us this site is ok, but we know that this value is wrong because if the core has been down over 1 day obviously the sub site (Mequinenza site) has been unavailable 1 day too.
I believe than dependency would only affect to Dashboard view and Actios, I don'k know if it is a issue or if Zabbix work as I describe, if it work as it, may be could be keep on mind for instance have a check box to specify how the dependency are going to work (Action Yes/No, Dashboard Yes/No, IT Services Yes/No ...)
Regards,
Julio
Scenery
HTML Code:
Triger name: "Mequinenza-not-connected"
Expresion-> {Mequinenza:icmpping.last(0)}=0
_____________________________________________________
The trigger depends on->
H_Barbastro_WAN1 not-connected
H_Barbastro_WAN2 not-connected
Event generation-> Normal
HTML Code:
Site: Mequinenza Status calculation algorithm: "Problem, if at least one child has a problem" Calculate SLA: "Yes" Link to trigger?: "Mequinenza-not-connected"
Regards,
Julio
