I can't import
  • hsoussou
    • Mar 2010
    • 21
    I can't import
    I tried to export a template "Templates_Windows" but when I do it, the file xml is empty !!!
    The same thing when I try to export another agent
    Thanks in advence
  • jmedina
    • Jan 2010
    I have the same problem...
    any idea ¿?
    • simix
      • Jul 2006
      • 53
      Do you have php-xml installed?
      • jmedina
        • Jan 2010
        at this moment .... YES !!!!!
        and it work fine
        • jerrylenk
          • May 2010
          • 62
          PHP silence!
          The other day, I had a similar problem.
          Nothing to do with zabbix, quite a different story, but a php module missing.
          It had me pulling out my hair, because there was not the slightest hint or error message, not in the webserver log nor the php error log, simply an empty output document!
          Seems they love to keep admins wondering.
          • boy01
            • Dec 2007
            • 24
            Hit me today!
            Shouldn't it say something smart instead of empty file...like:
            "I this file is empty, maybe you are missing php-xml."
            • untergeek
              • Jun 2009
              • 512
              I frequently have problems with other web browsers.
              Safari doesn't like to import/export templates.
              Firefox sometimes has issues.
              IE sometimes has issues.
              I've had to use Firefox or IE to import/export successfully.
              • unclecameron
                • Mar 2011
                I've tried various combinations of FF/IE in Linux/Win, is there a command line tool to do it after I scp the xml to the server?
                I'm running Debian Squeeze, there is no php-xml package, but have installed php-xml-parser and php-xml-serializer and restarted apache. The import says it's successful, but it doesn't appear in the template list, or as an option to link to a host
