Add group with Mass update for host remove existing groups
  • pcamelio
    • Jul 2005
    • 67
    All is in the Title
    Zabbix version 1.8.2
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    When you create/update host you select in which groups host should be.. Why mass-update should be different in this approach? i.e. you select in which groups should be selected hosts, from others it will be removed, same as for single host!
    If you wanted to add many hosts to a single group you should done it through group update form..
    Zabbix | ex GUI developer
