zabbix database is down
  • ploochan
    • Oct 2009
    • 42
    I have the 1.8.2 Zabbix, and today I received an email from Zabbix, that the database is down. Once I logged into Zabbix, all was ok. Any ideas what this means? I wasnt able to find any errors on the logs.
  • dotelpenguin
    • Feb 2009
    • 14
    This can happen if the database can not be contacted. I had this problem when running Zabbix on an older machine, and was abusing it.
    Check to see if you database is crashing and restarting. This can also cause the problem. also if your database is located on a separate server, SQL or ORACLE, and networking is lost, you will see this.
