Crash Zabbix
  • psychomoise
    • Jun 2010
    • 9
    Crash Zabbix
    Hi
    I have a big issue, the service zabbix_server crash just after starting.
    here are the log from the service
    28920:20100605:033642.065 Starting Zabbix Server. Zabbix 1.8.2 (revision 11211).
    28920:20100605:033642.065 **** Enabled features ****
    28920:20100605:033642.065 SNMP monitoring: YES
    28920:20100605:033642.065 IPMI monitoring: YES
    28920:20100605:033642.065 WEB monitoring: YES
    28920:20100605:033642.065 Jabber notifications: YES
    28920:20100605:033642.065 ODBC: NO
    28920:20100605:033642.065 SSH2 support: NO
    28920:20100605:033642.065 IPv6 support: NO
    28920:20100605:033642.065 **************************
    28930:20100605:033644.161 server #7 started [Trapper]
    28920:20100605:033644.163 server #0 started [Watchdog]
    28931:20100605:033644.177 server #8 started [Trapper]
    28934:20100605:033644.177 server #11 started [Trapper]
    28938:20100605:033644.178 server #14 started [Housekeeper]
    28938:20100605:033644.179 Executing housekeeper
    28933:20100605:033644.179 server #10 started [Trapper]
    28936:20100605:033644.181 server #12 started [ICMP pinger]
    28937:20100605:033644.182 server #13 started [Alerter]
    28939:20100605:033644.182 server #15 started [Timer]
    28941:20100605:033644.184 server #17 started [HTTP Poller]
    28943:20100605:033644.184 server #19 started [DB Syncer]
    28944:20100605:033644.185 server #20 started [Escalator]
    28932:20100605:033644.186 server #9 started [Trapper]
    28924:20100605:033644.189 server #1 started [DB Cache]
    28920:20100605:033644.506 One child process died (PID:28944). Exiting ...
    28920:20100605:033646.542 Syncing history data...
    28920:20100605:033646.542 Syncing trends data...
    28920:20100605:033646.542 Syncing trends data...done.
    28920:20100605:033646.542 Zabbix Server stopped. Zabbix 1.8.2 (revision 11211).
    I have the same result with version 1.8.1
    there is something strange, I check "dmesg" and I found this :
    [ 6873.232234] zabbix_server[28944]: segfault at 0 ip b72457bc sp bfb2aba0 error 4 in libc-2.11.1.so[b7215000+153000]
    Iam under this kernel : Linux zabbix 2.6.32-22-generic-pae #36-Ubuntu SMP Thu Jun 3 23:14:23 UTC 2010 i686 GNU/Linux
    Right now our monitoring is down and we are blind.
    What do you think of this issue ?
  • MrKen
    • Oct 2008
    • 652
    Doesn't appear to be an error within Zabbix.
    Google this: "segfault at 0 ip" libc-2.11.1.so ubuntu
    No wait, I've done it for you: http://www.google.com/#hl=en&q=%22se...409f7759ed9c90
    Have fun!
    MrKen
    • psychomoise
      • Jun 2010
      • 9
      I am not so sure about this.
      I was working with zabbix for about 1 year (great tool by the way) with a mysql database.
      we had recently got some issues with mysql so two days ago I switch to postgres and since I have this problem. I switch few minutes ago to mysql and zabbix 1.8.1 (with the package from ubuntu version 1.8.1) and it is working well.
      So, the problem appears with both the package zabbix-server-postgres (version 1.8.1) and a version 1.8.2 compiled by me with those options :
      --enable-server --enable-agent --with-pgsql --with-jabber --with-libcurl --with-net-snmp --with-ldap --with-openipmi
      I will wait for the new glibc (version 2.11.2) maybe it will be solved with it.
      I already googled it and I found a lots of people having the same problem with this version of the library without any solution.
      If the problem exist due to glibc, with which version of glibc I need to compile zabbix to work with postgres ?
