Check Apache running on certain IP always returning 0
  • cermisch
    • Nov 2005
    I am pretty new to Zabbix and still trying to figure out our setup.
    I managed to check for SMTP and SSH service using the agent - that was pretty straight-forward. But now I want to check for http and https which only listens to a second IP on te same physical server.
    After looking through the manual I came up with these two options:
    Using the agent: check_service[http,83.220.131.80,80]
    Using simple check: http,83.220.131.80
    Both of the above checks always return 0 even though the webserver is running perfectly.
    Any ideas what I am doing wrong? Thanks in advance...
    btw: we are using Zabbix 1.0 on a suse linux 9.3 system; client is installed on a suse linux 10 with apache2 to be checked...
  • cermisch
    • Nov 2005
    I might add, that if I setup an own host for this IP in Zabbix and do a simple check http,83.220.131.80 if does return the correct value (1) for Apache.
    Any ideas?
    • elkor
      • Jul 2005
      • 299
      can you do a wget for index.html to the offending ipaddress manually from the zabbix server command line?
      • cermisch
        • Nov 2005
        the problem is solved...
        we only opened up port 80 as the destination port on in the firewall. but the agent seems to wir for a response from apache with port 80 as the source port.
        so allowing the server ip to contact itself with port 80 as source port solved the problem.
