We would like to use two "Status of hostgroup trigger" modules in 1 single screen.. It seems to work, but none of them are filtering the triggers according to the selected hostgroup. So both show all triggers.
Even when using only 1 module, it doesn't filter the triggers correctly.
Is this a known issue or am i doing something wrong?
The zabbix version we are using = 1.8.2
Thanx!
Scheffie
Thanx!
Scheffie
